P
Piratepete
Hi Guys
I've been asked to install a fitting that has no enclosure around the (floating) terminal block.
It's a Homebase Newport Small Fitting QA01572. The base sits away from the ceiling on 3 25mm long pillars. Between the base and the ceiling is the unfixed terminal block. The instructions tell you to connect the fixed wiring to it and wrapping it insulating tape! Obviously this is visible and accessable, especially if used as a hall light at the bottom of the stairs.
My understanding is that the terminal block has to be totally enclosed.
Your advice please?
Cheers
Pete
Your advice please?
Cheers
Pete
