non contact voltage detector for £1.98 | on ElectriciansForums
Discuss non contact voltage detector for £1.98 in the Electrical Tools and Products area at ElectriciansForums.net
ExArmy
cumbria
But you have to provide your own batteries...
I have a couple lying around somewhere as they tend to get thrown in for free when buying other stuff as have others no doubt.
Looks like a fluke copy,only problem I found was if you drop them the little bit of plastic snaps off and then its knackered,or at least it was on my fluke.
i'm gonnna order a few also i think, just for spares. makes me mad i spent £20 on a fluke one and it's not as good as a £10 metrel one i had previously. the metrel was always on, and picked up voltage through HR flex, SWA, big enclosures but the fluke is crap, and the fluke goes mental in a CU for some reason?
You think thats annoying,I lost mine went straight out and bought another 1 then the day after a fluke rep gave me one for free,and to cap it all same day someone came and handed me my original one back that they had "borrowed" out of my bench drawer the day before!
Have you noticed that if you leave a bit of kit on a job no one phones you to say you have left it there. Sometimes it could be 3 weeks before you realise you are missing it and then you have no chance of remembering where you left it!
I was leafing through the CPC catalogue when I came across the Duratool Voltage Test Screwdriver which I thought was shocking enough for a trade catalogue, but it's description hit a new marketing high and safety low point:-
  • An all-weather voltage test screwdriver for voltage, polarity, continuity testing, bulb/fuse testing and microwave leakage detection. Features an integral LED indication and contact/non contact inductive testing.
  • Continuity measuring ranges - 0 to 50MOhm
  • Voltage measuring ranges, AC - 70 to 600V
  • Voltage measuring ranges, DC - 0V to 250V
Technical Data
AC Voltage Test
Contact 70 to 250V ac
Non-Contact 700 to 600V ac
DC Voltage Test Up to 250V dc
Polarity Test 1.5V to 36V dc
Continuity Check 0 to 50MΩ
Microwave Leakage Detection ≥5mW/cm [SUP]2[/SUP]
D01778 - DURATOOL - VOLTAGE TEST SCREWDRIVER | CPC
Does anybody fancy using one in wet or humid conditions as a contact voltage tester to validate the all weather claim?
im wary about these cheap versions. A friend of mine had a cheap one and it was very inaccurate (i know they aren't exactly brilliant) and would light/beep when it chose to. Compared with my megger version which was a a lot better. Although you pay for it.
Technical Data
AC Voltage Test
I'm not going to lie..... I'm nervous enough using one in the dry!
Reply to non contact voltage detector for £1.98 in the Electrical Tools and Products area at ElectriciansForums.net
I have the Kewtech that I bought in an emergency when my trusty Fluke that lasted many years gave up. It works! It has single pole testing too btw...
