Non Part P compliant work? | on ElectriciansForums
Discuss Non Part P compliant work? in the UK Electrical Forum area at ElectriciansForums.net
London
an electrician has installed a spur fuse(?) as part of a bathroom under floor heating installation. They removed a redundant plug socket just outside the bathroom and re-used it to instal the spur fuse. Several days later I noticed it wasn’t straight so thought I’ll straighten it when I come to paint the wall and need to remove it. Having done that I’ve now noticed that the original metal box is too shallow and I cannot screw the cover back on. The fuse unit would never fit in a box that shallow, I realised they actually filled round the edge, probably because there was a gap. Also there are no rubber grommets on the cut outs where the cables come in. I’m wary of trying to force the cover on in case the wires are cut by the box cut outs and the box becomes live. Does the use of an incorrectly sized box and the lack of rubber grommets mean the work is non compliant? Many thanks in advance.
non - compliant ?
more like badger bodge
no grommets is a bit rough , as is trying to crush cables into a shallow back box
in the perfect world it will need a new deeper box and re-terminating by a sparks
Can I threaten them with anything to ensure they come back, if it’s non complaint can they be struck off any approved register? Thanks
Bit much TBH why not contact the electrican explain you've had professional advice and you would like for them to come back to rectify it.
Nothing is saying they wont just pop back and sort it out.
Not fitting grommets is IMO poor. The cables are not sufficiently protected against mechanical damage by the often sharp edges in KO boxes. See this all the time though.
Using a box that is too shallow and filling around the edge is possibly not against the regulations as it sounds like it met the IP2X on top surface and IP4X on others after they lashed it up with filler/decorators caulk. It is bloody poor though. It's certainly a poor quality of finish. That's not to mention the fact that it wasn't screwed back level.
Sounds like a bit of a rough job to me.
I would say he's in breach of:
Regulation 134.1.1
Good workmanship by skilled or instructed persons and proper materials shall be used in the erection of the electrical installation. The installation of electrical equipment shall take account of manufacturers' instructions.
That my be just my ignorance, I thought that was the standard that domestic electric work had to comply with ?
No BS7671 and any relevant other applicable standards.
Please don't tell me that
You are Part P qualified
Part P approved
Have an 18th/ Part P tester
Installing an 18th/Part P consumer unit
Going to issue a Part P certificate
or any of the other nonsense that gets around.
It is totally misleading.
Reply to Non Part P compliant work? in the UK Electrical Forum area at ElectriciansForums.net
