Can anyone advise where I could obtain a chrome “ normally on” switch plate. Sorry if I’m not being very clear but the switch needs to be momentarily off when the switch pressed, the opposite to a bell push.
Discuss Normally on bell push in the UK Electrical Forum area at ElectriciansForums.net
That may fool plod, but not his four legged companion! & were you supposed to publish the master plan on the inter web?!I have built a hidden door book case for a customer, from inside the room there is a micro switch operated by the movement of a book, however on the other side ( the back) of the book case is a hall and my client wants a light switch looking switch to match all the others in the hall.
As you ask , do you think that if I use a 1 gang 2 way switch with the live one and live 2 terminals bridged it would result in a momentarily break of current when operated. The door is built so that when the electromagnetic lock is released the door swings ajar.....or am I being stupid. Oh and it is all only 12 volt.
Yes, a 2-way switch is 'break before make' configuration of contacts so there would be a very short break of current if you wire it as you suggested. Problem is that with magnetism things happen relatively slowly and you may find the break in current isn't sufficient for the magnetic flux to decay or break down to a point where the door releases. It would be trial and error.....do you think that if I use a 1 gang 2 way switch with the live one and live 2 terminals bridged it would result in a momentarily break of current when operated. ....
What make and model switches exactly do they have?.....my client wants a light switch looking switch to match all the others in the hall.......
I have built a hidden door book case for a customer, from inside the room there is a micro switch operated by the movement of a book, however on the other side ( the back) of the book case is a hall and my client wants a light switch looking switch to match all the others in the hall ( which is the item I’m looking for).
Reply to Normally on bell push in the UK Electrical Forum area at ElectriciansForums.net
