Not a bad effort for a DIYer... | on ElectriciansForums
Discuss Not a bad effort for a DIYer... in the UK Electrical Forum area at ElectriciansForums.net
That guy needs some insulated screwdrivers if he wants to play electrician.
Anyone selling
At least the socket wasn’t chased into the brickwork
I used to have a bunch of those until some fella called Tel kept buying them off me :)
A house I was at recently:
(+1 for the mother of all drip loops ? )
[ElectriciansForums.net] Not a bad effort for a DIYer...
Then it was plugged in inside a lean-to:
-non rcd protected socket
-socket is a spur off a spur off a spur (with washing machine and tumble on the middle one)
-no earth sleeving inside
-no grommet and only single insulated ends poking through
-socket hanging off wall when I discovered it as pictured. ("If you do the screws up it trips, so I leave it like that")
-flex damaged
Apart from that it's fine. "Last guy never said anything!"
I suppose we ought to be a little generous with our criticism in case he does have a genuine problem, but at what point do you draw the line on possibly someone following a dangerous procedure?
Reply to Not a bad effort for a DIYer... in the UK Electrical Forum area at ElectriciansForums.net
This is an RSS feed of thread: Home Diyer posting for account to remain Content of the thread: Quick hello, Need to keep my account. Home Diyer...
This is an RSS feed of thread: Home DIYer posting to retain account. Content of the thread: Drayton equipment fitted to CH system & very old...
