Not happy with this John Lewis design - non compliant. | on ElectriciansForums
Discuss Not happy with this John Lewis design - non compliant. in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
Just put this light up.
35mm gap between the shade and ceiling - you can get your hand in and touch the chock blocks.
Not right is it.
Not sure I can work around so I guess it’s got to come down.
Not good.
[ElectriciansForums.net] Not happy with this John Lewis design - non compliant. [ElectriciansForums.net] Not happy with this John Lewis design - non compliant. [ElectriciansForums.net] Not happy with this John Lewis design - non compliant.
How can they sell such carp is beyond me...
If we installed a consumer unit with a hole in the top big enough to fit your entire hand in we would get crucified by the scam inspectors and rightly so
Buts all ok for a retailer to not follow the rules
Just a thought... but are the chock blocks supposed to be in the wall ? If they were, it's basically the same as any other light fitting in that you can touch the lamp holders etc.
Playing devil's avocado, it's not too different, safety wise, to a standard pendant.
BS7671 gives the installer responsibility for the selection and erection of appropriate fittings and materials, so if you don't like it, just say no.
But you can't get to the actual connections (terminals) on a pendant. Looks like you can with this.
But you don't need a tool or key to open a pendant base either. Both sets of terminals in both fittings will be IP2X, and I'd assume you can take the glass off to change the lamps in the crappy light fitting so there should be no need for blind fumbling.
Like I say, just offering the opposite argument. I think that fitting is dire.
I'm with Andy78 on this.
The choc block / terminals should be safe to touch whether the glass is on or not.
You can see the cables on this one and it's a third the price of Jonh Lewis and probably made in the same factory;
I don’t like it but if the instructions say it is suitable for the environment and position it is in then it is compliant?
CE marked I presume.
It is presumably compliant in the same way that 240v track lighting is.
If you cant get a B.S. finger in it then it's compliant.
Agree with above comments RE. not being able to touch live parts of terminal block with fingers.
However I also agree with above comments that it's a POS and should not have been made that way, the same reason I don't like 240v track lighting.
I’ve refused to fit many lights I don’t like the look of safety wise.
These so called double insulated lights that have a skimpy bit of rubber tubing to fit your cables in that makes it double insulated.
I really don’t understand how they ( manufacturers ) get away with it.
Of topic a bit. I was called out to a dimples plug in heater that was overheating the socket.
How can you get a plug in anything that is 3 kw?
I get there and I couldn’t touch the plug it was so hot.
The heater was 3 kw on a plug. I tried to explain how in my opinion it was not compliant, but found it difficult as it has its CE mark and I looked it up on line and yes it’s sold with a plug.
....you can if you add 0.7 to the calcs?
Must admit,i've seen a few items on a plug top,with stated 3Kw....had a few fronty tech replies about clamping during use...usually say i will plug it on on the test-bench....when i find my oven-glove?
3000/230=13. The BS1363 plug was intended to be able to supply a 3kW load, its Wylex competitor even had '3kW' moulded into the bakelite lid. Once upon a time, many heating loads were 3kW, but at the same time the reputable brands of socket had contacts made of real metal and plugs had fuse clips that the fuse really clipped into. These days a 13A socket is often only any good for 10A, which is a pity because Swiss 10A sockets are often quite adequate for 13A.
At home I have a 3kW radiant fire from the 1960s plugged into an MK socket of similar age, where it has been plugged since before I was born. I don't use it much but I remember it on for hours on cold winter nights before the house had central heating. The plug runs faintly warm to the touch.
Reply to Not happy with this John Lewis design - non compliant. in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
