I have been tasked to sort out a tripping problem. It's on outside light set in concrete blocks it's an old system and the "brick" lights aren't water tight. A couple of months ago they tripped out. And last night I had a look to see if it was a simple problem I flicked the switch to see if the problem had rectified itself - thinking water may have caused the initial problem it tripped out straight away. Re-energized the lights stayed on for approx 3 mins then tripped again. I dismantled the guts of the lights one by one and discovered a chard lamp/lamp holder disconnected this. Re energized pop straight away - powered up again almost straight away and they stayed on from approx 3 mins then pop. It's protected by an MCB - do they need to be up-graded to an RCD because they're outside? Why aren't they tripping out straight away on the second re-energizing? I thought if there was a problem like a short circuit they'd go in x amount of time even if you re-energized 100 times?
I'm not a fully qualified spark but could you please give me a few pointers on how to solve this problem please and any explainationas to why would be grateful.
