R
ratboymark
hello
got some jobs comming up replacing 6mm tails to 25mmm with 16mm earth all bonding is in place and meets regs but there is a good chance i wont be able to change the dis board witch is the re wireable fuses if i was to notify this i was thinking i would put on the eic that it was a alteration and client has been advised to upgrade distribution board do you think this would be the right way of doing it?
