N
newish
New control wiring for heating systems has to be notified to building control, but what and how do you fill in a certificate for this. I would like to be able to extend my scope of work but a bit confused.
Presumably you test the circuit up to the fused connection for the heating system but do you have to record readings from the control wiring and how. Because you've got links from the programmer to multiple stats then multiple valves then multiple pumps and then the boiler.
I'm also a little confused as to what has to be recorded for security systems on a similar basis.
Any help would be greatly appreciated.
