A
Araman
Having installed a new cu in a customers house I found the fan assisted oven (cooker only as the hob is gas powered and the cooker was fed through the ring main) was tripping the RCD constantly. There were no faults that I could find so I laid a dedicated radial to the cooker. This has very nearly cured the problem inasmuch as the RCD now trips only once about 5 minutes after the oven is switched on and thereafter never again.
The fan comes on as soon as the oven is switched on so it is not the motor starting up that is causing the RCD to trip.
I am happy enough to lay the radial from an independent non-RCD controlled supply which will end the problem. But do any of you out there know the answer to this? Where do you think the problem is? I know I comply with 17th edition by feeding the cooker through a FCU rather than a plug and socket but it would put my mind at rest if anyone knows the answer.
