Number of lights per sq/m domestic new build | on ElectriciansForums
Discuss Number of lights per sq/m domestic new build in the Domestic Electrician Forum area at ElectriciansForums.net
B
billy110
Hi fellas, did I read somewhere on this forum regarding the above? Head been stuck in OSG and I can't find anything, am I going mad!
Thanks in advance.
Reply to Number of lights per sq/m domestic new build in the Domestic Electrician Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Well conventional wisdom says that you just parallel ('piggy back') as many switch sources as you need, all fed to the contactor coil. If for...
Out of curiosity how do wet pants price a new build or string of new builds ? Price per rad , price per tap etc etc ? Plastering is easy pricing...
Actually ignore my comment - I've just remembered you said it was looped at the switch rather than 3 plated at the rose.
It's actually not as those are accidents outside of work, if you suffer an injury whilst working for someone else or doing private work then...
davesparks
