Number of Points Served. | on ElectriciansForums
Discuss Number of Points Served. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sparky123
When completing a periodic test certificate, I once read that a twin socket counts as 2 points is this correct??
No, I have always been lead to believe that 1 single socket = 1 double socket = 1 fused spur = 1 point
in other words the number of points served = the number of breaks in your cable.
I agree with the above post, however i know many will disagree..
The way i see it is why do you have to state the number of points on the scedule ?.....Surely the total number is mainly irrelevant in operational terms......But when undergoing Inspection the the Electrician can tell how many outlets
[POINTS] he has to locate... hidden behind furniture obstacles etc...if alterations have been made since the last Inspection .,Certification should have been provided updating this information.
regards...........spark1
Good question i was taught that 1 double socket counts as 2 points .In the 16th ed of OSG the way it is worded is slightly ambiguous could be read either way .One double socket has the potential to draw twice the current of a single current .So noting it down as 2 points makes sense to me.
Its the point of connection.
IE one for a double socket, single socket etc, one for a light fitting, regardless of how many lamps.
i was taught single or double is still one point ;)
Yep indeed!
HI Jason could you point me to some text regarding your post my good man
Yeah. What i said above:D:D:D
Sorry, no as that is what i was taught, same as Flukey.
Kinda makes sense really as your not going to count say, 4 lamps on a track light for eg. This would be classed as one fitting or point.:)
To be honest, i dont really think its that important.
I would be concentrating more on satisfactory test results.
Yep indeed!
No its just one of those niggly --- bits that i/people would like to know for sure .So your safe in the knowledge that what your writing down is correct and if challenged can say with authority.
You have to ask why we put the number of points in the first place.
Your track light although one connection has 4 lamps 4x 100watts for example so its drawing more current
Have been to a few jobs where lights keep popping, on further investigation turns out lights have been doubled up 20 lights on 1- 6 amp mcb.
So with this scenario number of lamps at a light ie 4 lamps on one spot has a relevance. that would be my take on it
the only thing i can find in the regs that comes close
is how a socket outlet is descibed in
543.7.2.1
and thats as clear as mud.
i have looked through the brb and osg.
As i said before this is what i was taught.
Im not saying its right or wrong as i think its just to confirm that there isnt for example, 100 lights on one circuit, but in my opinion is not as important as satisfactory test results.
Maybe a call to your scheme provider will give you the answer.
Thanks Guys for all your feedback
Still confused as to what is correct. It makes perfect sense to count a twin socket as 1 Point,
However it also makes sense to count it as 2, I will continuie to plough my way through my reference
books to find where I read it, When I find it I will repost.
Thanks again for all your help.:confused:
If you look in the on site guide 16th edition Not sure of the page No and not going to look anway
The IEE recomends a particular amount of points for a domestic
The lounge area advises 5 outlets
Now at the bottom of the figure it says in italics
All sockets are twin
Now if 5 outlets are considered as singles that would be 2 and a half twin sockets installed
Doesn't make any sense does it?
It would make no sense to consider an outlet as a single under these guidlines,so
My view is that the IEE considers an outlet whether single,twin.tripple to be counted as 1 point of utilisation
Reply to Number of Points Served. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Tesla & Porsche chargers come with a commando adapter that allows them to charge at 32a, if that’s the car in question. Which with clipped direct...
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
