Nurse Call System | on ElectriciansForums
Discuss Nurse Call System in the Talk Electrician area at ElectriciansForums.net
surreysparks
Hi All
I have a random problem with a C-TEC 800 nurse call system.
The sounders are not working, even though when the alarm is raised they receive 14VDC.
When I attach the pair from the sounders that is in the panel and connected to the sdr outlet to a toner you can hear both the sounders so I know they work.
Confused.....
Carnt say I have any experience of the c tec system but I know that some of the older fire alarm systems use to flip the polarity of the sounders to switch them on or off
That's just a total shot in the dark I have no experience of the c tec nurse call system
There is a common Neg and positive from the control panel to all sounders, plus a signal cable which is the zones trigger, you are allowed upto 3 sounders per zone. allcall points are just neg and trig
View attachment K_RANGE_STND_PANEL_INSTS_3.pdf
Instruction attached for 3 wire overhead sounder/strobe
That sounds about right to me, though i've never even heard of the C-Tech nurse call system, let alone have any experience of them...
We deal with alot of nursing homes for fire and nurse call although the c-tec 800 is not widly used. most of them Eng54 are just and adressable system like the fire alarms
The sounders they have are 1 pair, no trigger etc....
As tazz has uploaded the wiring instructions for the C-Tech 800 system in his post #4, look at the wiring connection requirements for the different sounder options. They can't be much clearer, for you to be able to sort it out from there!!!
Remote I beleive just a - and a +.
They get 14v, no noise.
Connect the paid from my toner to the + and - at the panel and they make noise....
So the sounders work.
They get voltage when a call is raised, but don't sound...
No idea about the system itself, but have you measured the voltage when in alarm, whilst it is connected to the sounders? IT may drop off significantly when under load.
It is possible that the supply is not man enough to provide enough current to operate the sounders, either from the panel design or the length of run
Ok there is your problem, you can only switch remote sounders from a sounder switch unit, they cannot be connected on the zone. But you can connect direct to the panel SND + and com - All calls will activate the sounders.
Reply to Nurse Call System in the Talk Electrician area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
