J
jassyo06
hi guys and girls as the heading says i have nearly finished my work for my nvq,i have been working for the last 5 months self employed in a small/commercial/industrial factory doing work ranging full office/workshop rewire that consisted of lighting/ring main in dado trunking/32 amp 3 phase isolator,10 way split consumer unit,heating/oilfilled for toilets/via time clock.installing pir's in all lighting areas,i even ran in new 16mm2 3 core for the supply of the consumer unit and the supply 10mm2 4 core for the 3 phase isolater all have containment via tray /trunking i have tested all circuits and supplied a test certificate and schedule of results
i have also done work outside consisting of led floodlighting/outdoor sockets ip66/320 ladder rack/6"tray 2.5mm2 swa.............etc,etc i have also done a whole load of work,
i have all this work in photos as proof plus also all the orders/copies from CEF wholesalers for which i ordered and signed for. i also have manufacturers data from products i purchased and installed,i have proof of recylcling old fluorescent tubesrecycle receipt,i have proof of a safe isolation procedure via photos....................and a bit more i know this a long post but is there anything else i need as supplementary evidence before i start the the site diary firstly on the (PC) Then finally on the actual diary or even any advice in genereal as i need to get this diary to bed as they say its been a thorn in my side since finishing 2330/2/3
