NVQ science and principles | on ElectriciansForums
Discuss NVQ science and principles in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
daventry
A coil is connected to a 100v a.c with 20ms, and supply current taken by the coil is 6a calculate the frequency (50Hz) the overall impedence (16.6 ohms) inductive reactance and inductance of the coil
Calculate the power factor and phase angle of the coil
Sketch a wave form of the voltage/current values which you have just calculated over two complete cycles and use this to explain why the current of an R-L circuit is said to be out of phase by the angle calculated
g) A capacitor is to be connected in parallel with the coil. If the capacitive reactance has the same value, in ohms, as the inductive reactance calculated above, calculate the value of the capacitor needed
If a capacitor is of a higher value is added explain what would happen to the voltage/current phase relationship
If the frequency was increased to 10l3 Hz what would be the new reactance of the capacitor from G above
Welcome to the forum. Rather than just posting questions like that, maybe explain what help you are needing and how far you have got.
Upvote 0
Reply to NVQ science and principles in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
Electrical Courses
