O & m manual help | on ElectriciansForums
Discuss O & m manual help in the Business Related area at ElectriciansForums.net
Edinburgh
hi huys looking for a bit of help i work for a family buseness , which landed a decent size industrial new installation wich we carried out no problems. Although now the customer has came back asking for an Operation and maintenece manual, the problem time. Does any one have one that i could use to help and add neccesary details ect. Or even know a good site to get one.
Cheers
Might be able to help, do you have as installed record drawings and list of equipment installed
Just checked , we do have one in word doc. but I wiil have to edit it to remove all referances to ourselves ,when do you need it by
Cheers
You can't get them of the shelf, it contains info on what equipment you have installed and planned maintenance equipment will require.
bugsy could you send it to me too and i will edit to suit myself .. thanks (i have pm you my email address) thanks lee
I would have to agree
This is not something that can be done with a generic solution as every site and the installed equipment is different
I usually use a loose leaf file and insert all the documents / installation sheets supplied with the equipment that has been installed, the as fitted drawings on paper and/or CD, the test certificates and any other documentation that is relavent
Thanks for all help/ comments guys. New to the site and lost the post till i found link to get the page up again. I knew some one could not just give mw the finished article was more looking for a guidance. we just had a few sleepless nights getting it ready, handed it in this morning .
Man its getting harder customer wanted low bay heat loss information too
Reply to O & m manual help in the Business Related area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
