Observations From France | on ElectriciansForums
Discuss Observations From France in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Mr.Simple
Guys, I will again point out that I am not an electrician but an electronics engineer, so please be patient with me. I recently chatted to a French electrician to identify some key and basic differences between here and France. I was surprised at some of them and thought that most had merit, and decided to share for feedback. Please approach this with an open mind rather than an automatic British is best.
1. They have no ring circuits, all are radial. Power is delivered via 2.5mm wires to up to 8 sockets protected by a 20A breaker. This means that a fault in the wiring results in the customer seeing no power in part do the cct, and they then call someone in to fix it. Here if a ring breaks down all of the CCT remains live and the customer is unaware of the fault.
2. High load appliances, dishwashers, washing machines, tumble driers etc, have dedicated circuits protected by appropriate breakers. This extends the concept that we use for cooker circuits.
3. The breakers in the Consumer unit are double pole switching both live and neutral. This means that if for any reason the polarity is wrong throwing the consumer unit breaker will always isolate the circuit. I know that people may argue that polarity is treated, but are there ever mistakes?
4. The bus bars (live and neutral) lie above the breakers, with the circuit wires coming from the bottom of the breakers. I think in the uk our live bus bar is at the bottom with the circuit lives coming from the top of the breakers. This seems plain wrong as we all know that electricity flows better downhill (electrons are affected by gravity too).
i welcome your thoughts
your points 1,2, & 3 all have thier merits, but as fot electrickery flowing better downhill, it's time for your tin hat. these used to be popular in france:
[ElectriciansForums.net] Observations From France
So that's why they say it;s best to install the consumers unit at a higher level, to get a better flow, marvelous
You can overdo it though, if the CU is mounted too high the electrons can get scared resulting in unstable voltages.
That will explain why CU's are usually mounted in cupboards. As a CU in a tower block would be very high It would be necessary to ensure that they don't see how high they actually are.
It's also the reason most wires are insulated, an ignorant electron is a happy electron :)
ah, but what about those electrons that have only done a Electrical Trainee course. should they be confined to ELV?
One very big drawback for applying all those items 1. 2. 3, which is the size of the CU that'll be required to contain all those extra MCB's. Then virtually double it for them being DP breakers!!!
But on the plus side, it would require a nice big dedicated space, rather than awkward access to our existing CU's buried at the back of the shoe cupboard or in a kitchen base unit, etc, etc......
Apart from the DP breakers, the wiring here in Ireland is very similar. We'd have two 20A radial circuits for kitchens (or more, depending on size of room),
We also have neutralised electrons, they don't know the difference between up or down, left or right.. Don't ask how the electrons get neutralised, its a long story......
Intresting post mr simple..
Point 1- big draw back of radials is loading isusses and u say if there is a problem the circuit stops working well this isnt true if the cpc is lost on one of the first sockets leaves the rest with no cpc connected could be very dangerous with some class 1 equip.
Point 2- love it if it suits.. Often wired dishwashers, tumble dryers microwaves on their own supply!
Point 3- yeah great idea to have double pole breakers commercially but domestically isnt going to happen i belive the rcd covers this adequatly enough.. Dont wanna do ourselfs out of any callouts!
Point 4- load of rubbish really!
you are quite right that there are likely to be more McB's than a typical uk installation, but is that a bad thing? However you are wrong about the size of DP MCB's they are exactly the same size as a uk variety, now twice the size. The French also seem to like to have CU's that have multiple rows of MCB' and these are not much larger that a typical Uk variety ( less wide but a bit taller).
Reply to Observations From France in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
