The Inceptor Omni is the latest addition to the Inceptor range of cost effective integrated fire rated downlights. The Omni allows the installer to select the colour of the light upon installation ranging from warm white, cool white all the way through to daylight.
We're offering an extra 10% Off throughout October with discount code OMNITEN
Not only can you select the colour temperature but the Omni comes dimmable as standard and is ideal for use in situations where moisture and low pressure water jets are a factor. This makes the newest Inceptor an ideal solution for kitchens, bathrooms and wet rooms as well as all living areas.
- Fixed bezel - IP65 Rated
- Adjustable Bezel - IP54 Rated (Sold separately)
- Dimmable as standard
- Fire rated
- Pre wired Flow connector
- Insulation support bracket
Cheers,
Ivan
