T
tombrooker84
Hello Guys,
I was replacing a light switch today in an attic, just a little job I thought I would do on the way home. Anyway I isolated the upstairs circuit which it was fed off, tested for voltage (none present) and started removing the switch. The switch I might add contains the neutral for the circuit. Anyway disconnected the supplying cable and a got a small shock. Got my tester out, tested the circuit for voltage again, still nothing, just out of interest I got my volt stick out and sure enough its glowing like mad, so definitely something there, anyway turned the downstairs circuit off and the volt stick stops glowing, I checked all the 2 way switches they all seem fine. By the way its off a dual rcd board and both lighting circuits are fed off different rcd's. Any ideas?
Kind Regards
Tom
Kind Regards
Tom
