Dunx
Called out to repair some cabling today. Cable Tv guy has drilled through the ring main cables, completely severed one and nicked the insulation on the other. Old metal clad CU with 4 rewirable fuses, all found intact but the 60A main fuse had blown. Hacked out the scene of crime and decided to do temp repair, checked the ring continuity and ok on L & N but no continuity on earth. Reconnected the three and retested and found that I had 8 ohms live to earth and same on neutral. Continuity still ok on L/N but none on earth. Disconnected and left a section that tested ok
It was nearly seven pm so we have left as a radial on 15a, can't quite get my head round it at the mo, any thoughts? Is it possible that the cable has been damaged elsewhere?
