Odd question re feeding in | on ElectriciansForums
Discuss Odd question re feeding in in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
SPARTYKUS
Hi
just something Im trying to ponder in my head - if a house has Solar (PV) feeding into a CU, and the CU has 12 odd circuits (on RCBOs), and one of them has a N-E fault, as in, a dead short, would this mean that the energy fed back into the grid via this CU would ...feed back in?
surely there must be some loss if theres a (very low ohm) N-E fault?
Can anyone help me understand if this is the case or not as I admit its stretching my brain.
All electricity meters measure current flow in the line (as far as I know); the neutral is just used for voltage reference. So a neutral-earth fault will have no effect on the energy measured.
Reply to Odd question re feeding in in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
