Off peak supply | on ElectriciansForums
Discuss Off peak supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SimpleSimon
Can I get away with this?
Did a board change and left two economy seven heaters RCD unprotected. Power supplying them doesn't come on until 00:00-06:00. Just two radials each rated at 16a?
Reply to Off peak supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
