Off peak | on ElectriciansForums
Discuss Off peak in the UK Electrical Forum area at ElectriciansForums.net
T
tbs1983
Is there a way with the new digital meters to turn the off peak supply on that I can test the storage heaters I have just installed without going back there in the middle of the night ?? !!
I remember an old colleague of mine doing it on a job a few years back with an analogue meter, but never come across it with a digital.
Thanks in advance.
p.s. the meter is one of the pre pay top up with a key type if thats any help
I don't know for sure, but I doubt that it's possible.
In a similar situation, I've just fitted a temporary link from a breaker on the 24h board to the main switch on the off peak board for testing purposes.
Edit: As he says ^^^^^^. Whatever's the easiest way to get the off peak board powered up.
Reply to Off peak in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Ofcourse all replaced and labelled after.
