Offshore oil rigs | on ElectriciansForums
Discuss Offshore oil rigs in the UK Electrical Forum area at ElectriciansForums.net
B
bclions2172
how do I get on an offshore oil rig? What certification and qualifications do I need? Is there a list of relevant companies or recruitment agencies? All the job ads seem to indicate that I need at least 2 years offshore experience, how do I obtain the experience?
B
Hi
If you check the jobs section of the forum, you will see numerous threads on offshore work.
I believe the current industry minimum is Compex, Bosiet & MIST, around £2000 worth of courses there.
It is very much who you know as opposed to what.
I forwarded a job ad for a rig sparky a couple of days ago, its on the board.
Electrical Rig work would best be suited to experienced industrial based electricians, rather than installation based electricians. You'll be expected to get rotational and other machinery, along with many other systems, up and running during faults and breakdowns!! ...All working under pressure in sometimes very hostile conditions, to get production back on line!!
Reply to Offshore oil rigs in the UK Electrical Forum area at ElectriciansForums.net
J
Breakdown of costs to become "oil" qualified & OFTEC registered Hi all, Please can you advise on the above, estimates of costs would be fine. I...
Jim Goodenough
J
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
As above, you really should be capable of dead testing first, as 230V is quite capable of killing or causing bad burns, etc. If you are thinking...
If this is only a temporary thing, I doubt that you'll save over just leaving the immersion on. The 'stat will only switch on occasionally to...
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
