Discuss Ohms law in the UK Electrical Forum area at ElectriciansForums.net
Also if you want V...
V2 = PR is the same as
V = square root (PR)
Anything you move in a formula (to the other side of the =) changes its designation so:
square becomes square root.
Items above the line on one side move to below the line on the other (and vice versa).
So if you have a problem with maths (particularly with more complex equations) you can use this rule to manipulate the formula and leave your subject on its own (and above the line).
In your example the R (which is below the line) is simply moved to the other side of = and placed above the line (next to P) leaving you with V2 on its own.
P = V2
xxxxR
becomes...
PR = V2
If your required subject is R then you first move R to other side of = to ensure it is above line then move the P so the R is on its own...
R = V2
xxxx P
This method stands good for most formula you come up against in theory to level 3 - and you don't need to worry about multiplying both sides with anything.
Reply to Ohms law in the UK Electrical Forum area at ElectriciansForums.net
