E
edrobbo8
Hi,
I have a customer who needs a CU upgrade, the water pipe is bonded ok but the oil pipe for the boiler comes in underneath the boiler and is not visible and could not be touched, what happens about bonding in this case? I believe it needs bonding but does anyone have any proof of reg? Was going to IR between it and the MET to work out if over 22kOhm and prove if it is extraneous.
Thanks.
Thanks.
