Today I tried my hand at installing a fuel pump relay and oil pressure safety switch, but didn't quite get the result I'm looking for. The fuel pump isn't supposed to run until the oil pressure sensor hits 5 psi, but right now the pump turns the second I hook the ground cable up on the battery (key off), so obviously I've got my constant wrong, but not sure how to make it all work together. This is how I have it right now:
From the relay:
30 - to battery +
85 - to ground
87 - to fuel pump
86 - to "C" on oil pressure switch
From the oil pressure switch:
NC - to starter solenoid
NO - to ignition wire
Any ideas would be great. Thanks.
From the relay:
30 - to battery +
85 - to ground
87 - to fuel pump
