Discuss Old 3 Phase Board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, what would you code this Distribution Boar? A picture should be attached.
Andy
whats the matter with pocket sized fluke meters?
Have seen photos and read many reports about using meters being used for checking voltages with the wrong setting, e.g. amps or resistance setting when checking for voltage.
Photos are not very nice.
With the T5 pictured, that doesn't even matter. If you check volts on the ohms setting, for instance, the meter will just squeal at you. It's designed to be "self preserving", you might say.Have seen photos and read many reports about using meters being used for checking voltages with the wrong setting, e.g. amps or resistance setting when checking for voltage.
On the other hand, here's a picture of the inside of a buddy's Fluke 87 that was accidentally used on 4160V. It didn't stand the test:
Well, he was only off the site for a short period of time. Long enough to wash the soot off his hands. The fellow was lucky. Pretty nice fireball. I'm not a palm reader, but I think his palm says, "You just used up one of your nine lives".If you work on at a location like I do where you have a SAP and found you are not using a GS38 approved test lamp and proving unit, you would be off the site straight away.
Is that friction burns ?Well, he was only off the site for a short period of time. Long enough to wash the soot off his hands. The fellow was lucky. Pretty nice fireball. I'm not a palm reader, but I think his palm says, "You just used up one of your nine lives".
Reply to Old 3 Phase Board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
