Old gas pipe | on ElectriciansForums
Discuss Old gas pipe in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Dorset
Doing an EICR of a large B&B place. Totally re-wired in 2008 so not a big issue as its well labelled and been done to a good standard.
Not sure on 1 bit though.
In the cellar, gas and water pipes are bonded fine. But it looks like the gas had been upgraded at the time of the refurb and the old gas pipe has been terminated just outside the cellar in a small corridor, where I guess the old meter was. Old bonding cables to it have been cut etc. but still some evidence of it being there previously.
Didn't test to see if it was extraneous but If I do and it is I assume it should still be bonded? Although in theory its on the Gas Board pipe and no facility to bond on the customer side of a meter!
Why not?
It wont be a live gas supply, it will have been disconnected when the new MDPE (yellow) supply was put in.
So it's a piece of steel pipe in the ground that doesn't belong to anyone, so bond away if needed.
Reply to Old gas pipe in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This is an RSS feed of thread: Gas or Water Pipe? Look to find cause of damp in wall. Content of the thread: Hi all, First time post so please...
Bonding cables don't need to be insulated, other than for a short section at the end to identify them, and as long as they're 4mm2 or greater are...
I would imagine all of that steel structure is bonded. Can it not just be bonded to that?
`Just wasted an hour doing the same, and came to the same conclusions. 600mm is only mentioned in respect of gas meters from the 14th on, and is...
4K
Surface trunking.
