M
Mills87
Hello,
While pulling up floor boards for plumbing purposes (1950s semi detached) I came across an old style junction box (black plastic and screwed) attached to a joist. This is for the downstairs lighting circuit from what I can tell (size of wires and disappearing into the ceiling in a position corresponding to a downstairs light gave it away). I know currently these days junction boxes if not accessible (i.e. under floor boards under carpet) they need to be the maintenance free type. Therefore I was wondering whether :
A) It should be replaced with a Wago box or similar? As a like for like replacement.
or
B) Or is it a case of; Best to leave it alone as if you touch the existing installation, the whole circuit needs updating to current regs? (currently black or red, PVC sheathed + Earths, modern CU)
Cheers,
Martin
or
Cheers,
Martin
