Old lighting cables in new install | on ElectriciansForums
Discuss Old lighting cables in new install in the UK Electrical Forum area at ElectriciansForums.net
Rotherham
Hi everyone, newly qualified spark here I went to a job earlier today where the fan was not running on after light had been turned off. Whilst sorting this problem I discovered that the bathroom circuits had been installed on a new rcd db but investigating further in the light and the pull switch the old cables were still in use with the new installed cables. Is this against regs or does it comply if sleeved up? Thanks.
All ok, I would sleeve it but it doesn’t necessarily need to be in my opinion.
Board would require a sticker advising to be aware that old and new colours both used in the installation.
As Brian said, no need for the sticker anymore. Realistically if someone doesn't know what colour the cables should be they shouldn't be near it anyway.
Reply to Old lighting cables in new install in the UK Electrical Forum area at ElectriciansForums.net
Rcd protection?
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
