Old MK bakelite safety plug | on ElectriciansForums
Discuss Old MK bakelite safety plug in the UK Electrical Forum area at ElectriciansForums.net
marconi
Mentor
Supporter
London United Kingdom
I had to change the lamp in my wife’s bedside lamp and was reminded of this pioneering mk safety plug attached to it.
  • [ElectriciansForums.net] Old MK bakelite safety plug
Yes. And as a result, one of the deepest plug bodies ever made, as there has to be room for them to retract into pockets in the base moulding.
A good idea but a bridge too far for most users. I have not found any consistency to where they turn up, nor evidence of a site with enough of them to suggest that they were once the preferred plug type in that organsiation.
Yes. Look at the nicely plated fuse contacts in an MK plug like this, feel how the fuse snaps in and how the contact pressure is controlled and maintained by the embossed details. Compare with many modern plugs that offer a rather approximately bent strip of wannabe phosphor bronze that almost sags under the weight of the fuse. And the same goes for the socket contacts.
Reply to Old MK bakelite safety plug in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Hi, Thanks for the response, much appreciated. Yeah its 240v in Australia. The cable didn't smoke that I know of. The connection to the detector...
