old pyro pot | on ElectriciansForums
Discuss old pyro pot in the Australia area at ElectriciansForums.net
Hi,
does anyone know where I can obtain a 268 MICC pot and seal from?
If not, is there a metric one that will fit this old imperial pyro?
268 pot fits old 2C 0.002 cable dia.=6.81mm please check
metric cable 4L1.5 cable dia.=7.0mm please check
so 4L1.5 pot & 2L1.5 seal , now for the tricky bit you might have to solder the new pot on but its not as difficult as it sounds
or you could get any undersized pot and drill it out to say 6.9mm
yours benji
ps you could contact pyrotenax now TYCO
Reply to old pyro pot in the Australia area at ElectriciansForums.net
Missing pot from trapped gulley (Brand identification request) Hi Guys, I have a customer who has had building work done and the pot (if that's...
Stigster
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
