Old rubber and stranded cables | Page 2 | on ElectriciansForums
Discuss Old rubber and stranded cables in the UK Electrical Forum area at ElectriciansForums.net
London
Hi guys,
A customer wants an old re-wireable consumer unit upgraded.
Wiring is extremely old probably 1940's. Of the two power circuits, one is the old rubber cable and one is the old red and black stranded cable.
IR tests show ok L-N L-E N-E.
Problem is the cables have no cpc on the consumer unit side. I'm getting good zs on the sockets which are twin and earth radials on the socket end (so cables must switch via a jb or something under floorboards maybe).
But I have no idea where they are picking up an earth and there is no metal conduit either.
Should I go ahead and change the unit and sign it off even though I cant put the r1+r2 readings in because there is no cpc in the consumer unit?
In a lot of older installations ,the CPC was run directly from the main earth Isco , possibly in an unsheathed cable and possibly served a few circuits , just teeing of where ever necessary
Good call,seen plenty like this,where above,maybe a modern looking semi-rewire...and below,t&e cpc arrive at a JB,and leave via an ancient un-sheathed copper conductor.
Spiders' web under floor,joined together,wrapped round a nail/screw on a joist...
Some have given better than expected readings,when tested...although, a decent fault of fair duration,would anneal it some :ihih:
I think some people referred to it as a clothesline (although having looked I have been unable to find a reference for this term).
Reply to Old rubber and stranded cables in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
