Old school type (horizontal) QOT2020 breaker question | on ElectriciansForums
Discuss Old school type (horizontal) QOT2020 breaker question in the UK Electrical Forum area at ElectriciansForums.net
picker77
Central Oklahoma
What's the standard rule on the older horizontal or "side-by-side" QOT tandem breakers about which switch controls which circuit, since one of the hot wires is stacked or hidden behind the other?
Thanks!
I have ordered a couple of identical spares of this type breaker that I'll have in hand in a couple of days, at which time of course I can simply use an ohmmeter to answer my own question, but in the meantime here's a photo of five QOT2020's in this older style that are currently installed in my 1979 vintage QO 30-40MW200 load center. All these have the CTL "hook". There are authorized positions for 10 of these breakers in this particular panel. It appears that the more modern QO load center tandems have two vertically stacked switches, and the hot wire connectors are also visible and side by side, unlike these.
  • [ElectriciansForums.net] Old school type (horizontal) QOT2020 breaker question
Are you talking about the breakers being double tapped which is not allowed. One breaker one wire.
There is no standard rule for random breakers. They are designed to be able to add more circuits since a standard breaker is 1 inch and tandem breakers are 1/2 inch but still only one wire is
allowed
Reply to Old school type (horizontal) QOT2020 breaker question in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
those old mk rcds are very fast the figure you have quoted is the maximum allowed not the typical times,I have seen mk ones trip at 9 ms , the...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
The tandems will withstand the amperage that’s marked on the breaker. I’m my opinion you can use 20 amp tandem breakers. We are talking about 5...
