sparkyork
been to look at a job yessterday, one part is in a shop and the other works is in the main house. both buildings have seperate electricitry supplies.
shop electric works will be straightforward as ive got tt system with 10mm main earth bond and bond to gas in 10mm also got a 30ma rcd to use for the works.
other job tho needs his gas bond putting in so doing that first (he's with british gas so he reckons, who check his installation etc, i said i was suprised they didnt comment on the gas bond!!) anyway other works is just some lighting alterations etc. he's got an old wylex board which has one of the lighting circuits i need in it. i said im gonna have to protect any work i do via an rcd (logical place to do this is at the board), so im thinking of installing a small enclosure with rcd and extending lighting feed into this unit.
again this house is tt and is protected primarly buy an old earth leakage device, what rating are these things normally?? 100ma?? also main earth to electrode is 2.5mm so upgrading that aswell.
cheers and merry christmas
and also this old rcd has the connection to the electrode on it and the connection to the consumer unit. i want to install a seperate small consumer unit so what can i do with the earthing, is it acceptable to come from the old style rcd earth connection that goes to elcetrode and install a small earthing block so i can connect my new consumer unit earthing to this??
also are the old hollow earth spikes still acceptalbe are do they need swapping as well!!
