Old valliant combi control connections | on ElectriciansForums
Discuss Old valliant combi control connections in the Central Heating Systems area at ElectriciansForums.net
Seath
Southend on Sea
Hi Ladies and Laddies,
Could anyone help identify the terminals for this old combi? I arrived at the property which has been undergoing a renovation for the rental market, the client reported the boiler not working, when I began investigating the flex cables going into a mechanical time clock had been disturbed. I found the connection info for the time clock online but I cannot do so for the Valliant VCW.../1W combi. In the photo you will see the terminals 1,2 are supply in, but I am struggling to determine what terminals 4,5,6 do. The set up will be using a new time clock, as the original seems to have suffered over time and a two wire mechanical room stat.
Thanks in advance for any insights.
Duncan
[ElectriciansForums.net] Old valliant combi control connections
Reply to Old valliant combi control connections in the Central Heating Systems area at ElectriciansForums.net
