Old Work Box for Exterior Application | on ElectriciansForums
Discuss Old Work Box for Exterior Application in the UK Electrical Forum area at ElectriciansForums.net
zipperman
Florida
I plan to recess an existing exterior outlet into a cement block w/ stucco wall. I'd like to use a junction box that is easy to install and won't require messy cementing in. Can I use a winged old work electrical box on an exterior wall and caulk/seal it in well? And then use a weatherproof over everything. Maybe the carlon superblue or something similar?
Thanks!
Thanks!
zipperman welcome to the forum and yes you can use that style of box as long as it is recessed as you mentioned. Good luck
Reply to Old Work Box for Exterior Application in the UK Electrical Forum area at ElectriciansForums.net
This thread can now be closed, as I seem to also have space in the box for the first switch. Revised diagram below. Thanks folks.
