Old Wylex CUs | on ElectriciansForums
Discuss Old Wylex CUs in the UK Electrical Forum area at ElectriciansForums.net
Dorset
Anybody know the dimesions of the old Wylex boards?
I'm doing a quote to replace an 8 way and a 6 way which are butted up to each other and no spare room around them, didn't take the measurements whilst I was there, looks like I may have to fill with RCBOs rather than split board(s).
From memory they are 10"-12" x 6"-8"
Hope this helps.
Before I have done a CU change with 5 circuits (for main house) and 2 circuits for off-peak - I put both in the same board with RCBOs for main house and an RCD for the Off-Peak.
The home owner wanted only one board and not 2 side by side.
Have you thought about putting the 2 boards underneath each other? If there is room?
No room to put them underneath. All cables are rear entry so not really possible to put them into 1 large CU, without a lot of hassle! Both CUs are peak supplies, as opposed to off-peak.
Reply to Old Wylex CUs in the UK Electrical Forum area at ElectriciansForums.net
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
