Floody
Ok so in college last night I was given some papers that I missed on having just before Xmas due to being away. It's to do with the ohms triangle. I've nailed the maths side of it and I understand it perfectly well.
Theres questions in here, work out the voltage, work out the resistance, work out the current. Can do those without fail
until I came to this question which thrown me a bit... Now, I think it's just the way the question is worded that throws you, but ill show.
the question: The insulation resistance measured between line conductors on a 400v supply was found to be 2Mohms (2 mega ohms, 2million). Calculate the leakage current.
So my answer is: 0.2 x 10^-4amps. Or 0.0002amps
How I worked it out: the ohms law triangle says to find I, we need to divide V by R, so 400v / 2,000,000 ohms = 0.0002amps
is that right or wrong?
the only reason why I ask is because it says 'leakage current' and not 'current'
Thanks guys
Thanks guys
