On-off rocker switch with wall mounted LED controller | on ElectriciansForums
Discuss On-off rocker switch with wall mounted LED controller in the Lighting Forum area at ElectriciansForums.net
nextural
Aberdeen
Hi,
I'm new to the forum and working on a van conversion - I also dabble in guitar pedals!
I have a wall mounted LED controller hooked up to my down-lights. I'd like to be able to turn the circuit on/off at another location in the vehicle (i.e. to make a 2 way circuit). Is it possible to add an on/off rocker switch to the circuit - meaning there is a mix of both the LED controller and an on/off switch?
Space constraints at the new switch location (next to the sliding door), means there's not room for an additional controller - hence the compact rocker switch.
Any thoughts would be much appreciated.
Cheers
Reply to On-off rocker switch with wall mounted LED controller in the Lighting Forum area at ElectriciansForums.net
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
