one large house to a three flat conversion, what about the supply? | on ElectriciansForums
Discuss one large house to a three flat conversion, what about the supply? in the Australia area at ElectriciansForums.net
G
Grant M
A large house needs to be converted into three flats, does EDF need to come install new supplies for each flat. If that is the case how long does the procedure take and any idea of cost?
Or is there some other way of doing it?
Meter needed for each flat,get the meters put next to the Incoming,otherwise SWA or PYRO needs to be run between the supply and the meter,after the meter,you can run 16mm T&E,out of a 60/80A SFCU,sometimes they allow all three flats on single phase supply,(Diversity),but often incoming supply is only 6mm,yet they insist you run 16/25mm tails,plus 16/25 Subs to each Gaf,used to work for them,when they were under a previous guise and English owned...Anything ive left out...let me know...its been... .Emotional!!!
Reply to one large house to a three flat conversion, what about the supply? in the Australia area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Written in clauses are essential, but should be fairly standard fare to a solicitor. A similar situation exists around where I live with regard to...
