R
rocker
Did a job yesterday where the DNO changed an overhead TT for a PME.
As it was a long tails run, turned up with me switchfuse with a standard 80a fuse in it. Got told I'll have to put a 60 in because there's only an 80 in the main service fuse (even though it states 100 on the casing). Apparently the DNO will 'never go full whack' on the fuses. Told the guy it was going to be an 80 due to the size of the house and scope for development, and if his fuse goes first then tough. Then questioned the size of the incoming cable, which he said was 35mm concentric. not a chance. I'd say it was 16mm, possibly 25 if it had very thin sheathing. I then pondered using 16mm tails into my switchfuse (16mm armoured running to the cu) as mr dno had used 16mm tails from the meter to his cutout. Was told I'd have to use 25s.
So basically the guy who owns the house has been charged serious money to have this done, he's had to dig his own trenches, hire his own sparks to actually get the power to his house, and has been supplied with a substandard incoming service, a fuse which is more or less on the limit of what he's likely to consume, and tails that aren't to regulation.
But if we cut one of their seals we'll get told off. they're a law unto themselves and, not happy with screwing us with energy prices, they are ripping us off with their installations as well.
