I intend to replace the ceiling pull switch in my bathroom following a water leak from the flat upstairs which caused water to flow through both my ceiling light rose and the bathroom pull switch causing the light to now flicker in the bathroom.
I have replaced the ceiling rose but the light still flickers so I now intend to change the switch also and need to know whether this switch is a one-way or two-way switch.
The switch operates both the bathroom light and the fan in the separate
toilet.
In the toilet, the wall switch there also operates the fan and the light in the toilet.
The fan stays on as long as either the bathroom or toilet switch is on but the light in the bathroom only comes on and off when the bathroom switch is turned on (and, similarly, the toilet light only comes on and off when the toilet switch is actuated).
Could somebody please advise me if this is a one-way or two-way setup.
The present switch aslo has a sticker on it with "isolator" printed on it (if
this makes a difference).
Incidentally, the toilet light doesn't flicker even when both the toilet and
bathroom switches are on.
Many thanks.
toilet.
Many thanks.
