Open ends on ring circuit help | on ElectriciansForums
Discuss Open ends on ring circuit help in the UK Electrical Forum area at ElectriciansForums.net
Could be as simple as a poor connection / loose terminal screw (someone forgot to tighten it) , or as trickery as a nail trough the cpc
As above, most likely is a couple of wires in one screw terminal and one escaped when being tightened up (or screw loose).
Less good is someone did not bother to connect the CPC (earth) together at all, as that implies very poor workmanship.
Can someone explain what can trigger that issue. Open ends earth to earth on ring circuit? Thanks
Bad connection at an accessory, broken cpc usually a screw or nail; i have had a few on EICR rush were cpc has been on either side of a 2G socket and the link bar has been damages over years of damp ingress through the walls.
Was on eicr c2 ... Was qoute 400 for. How easy/hard Is to find that problem as it was mention it can cost more depends if it's hard to locate.. the second issue was found already
Normally within a couple of hours you can pin it down to two points or the cable between them.
If it's just connections at one of these points, it can then be a quick fix.
If it's the cable between them it can get a lot more involved depending on how the cable is run, floor boards might need to come up, plaster disturbed etc.
If it can't be found/fixed there is a last resort option of down-rating the circuit breaker and turning the ring into two radials.
Are you aware the property No and post code are on the attachment.
its a how long is a piece of string unfortunately, i have come against a few and all cpc are in place in the accessories and used a wandering lead from the earth rail to every accessory and there is an earth path but no ring continuity of cpc. Probably in a junction box under a floor the break. no ring cpc is my worst job tbf
Reply to Open ends on ring circuit help in the UK Electrical Forum area at ElectriciansForums.net
Well we called it a room, but it was only a hole in the ground covered with bit of canvas.
