I have a 15A external GFCI that tripped after a heavy rain. It's on a 4 GFCI circuit (3 interior GFCI outlets and 1 exterior GFCI outlet) and the exterior GFCI outlet is the last one on the circuit. I'm able to reset the other 3 interior GFCI outlets without any problem but the exterior GFCI outlet will not reset.
When I test the circuit breaker controlling the circuit it checks out OK. When I disconnect the exterior GFCI outlet and turn the circuit breaker back on I get 120 volts on the hot wire. But when I reconnect the exterior GFCI outlet it will not reset and still tests as open hot.
What could be the problem? By the way, the exterior GFCI outlet is brand new.
