A client has a Kenwood CK405 dual fuel range cooker, for which the smaller of the 2 ovens doesn't work. The elements tested out fine, but live tests showed that both N and L sides of the elements were at 230V to E, so presumably an open neutral.
I'm guessing it's a loose connection somewhere. However, as I'm led to believe that appliance wiring doesn't always follow the same rules that we follow, and that switching devices in the neutral are sometimes used, I thought I'd ask the forum if there was anything else that might have caused this?
