Opening factory-sealed cable tips | on ElectriciansForums
Discuss Opening factory-sealed cable tips in the Australia area at ElectriciansForums.net
L
lecnoob
Is there any way to break open your average pre-fabbed cable connector tip in such a way that you could re-use it? I'd like to replace the end of a DC cable without just chopping the end off ...
Reply to Opening factory-sealed cable tips in the Australia area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
