Opinion on self made trunking | on ElectriciansForums
Discuss Opinion on self made trunking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Malmö
I am covering a mess of conduit to get the CU out of a barthroom, all will be covered with plywood and silicon sealed, can't fit 90o bends in would be to difficult to pull conductors after anyway. Any thoughts main supply and a number of circuits are in conduit [ElectriciansForums.net] Opinion on self made trunking[ElectriciansForums.net] Opinion on self made trunking[ElectriciansForums.net] Opinion on self made trunking
can you take all that spagetti back to where it come out in the top right of the pic, then fit CU on the backside of that wall?
What's inside the plywood? Flexible conduit would probably do the trick. Unsheathed conductors, probably not so good.... what do the Elsäk-FS say about plywood as containment for singles?
Its quite had to make out as it seams it would be fine in plastic non fire retardent trucking! if all free conductors where to be housed in conduit flex and rigid mix but it still the bends that come out the wall which make it hard!
Reply to Opinion on self made trunking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
