Opinions on Wiring the lighting circuit at the 'switch' or ' at the 'light' | on ElectriciansForums
Discuss Opinions on Wiring the lighting circuit at the 'switch' or ' at the 'light' in the UK Electrical Forum area at ElectriciansForums.net
srl-8
Evening All,
I will be installing a new lighting circuit in new garage/bedroom conversion.
I usually always wire my feed/switch line/ loop etc at the pendent or first down lighter, However as you all know you can take the feed direct to the switch (s), and then off to the first light.
Can I ask, what are the advantages/ disadvantages of these two wiring options.
Does anyone have a preference or opinion. ?
Evening All,
Taking the live pair to the switch has an advantage of less cables at the light position, personally I don't like doing it. I'm old school and my preference is the old loop in/out method.
I prefer to wire through switches if downlighters or track lights are used due to too many wires, just like pete mentioned, if pendants then 3 plate preffered here as well, as it is a garage, who cares get on with it :grin:
Wow it's a while since we had this discussion.
3 plate at the light for me, I prefer it because the joint box you're using is made for it whereas a switch box isn't really meant to be crammed with wagos.
Just my personal preference though.
Thanks guys, I will be installing a timed bathroom fan as well. so 3 cables at a switch can get a bit of a tight squeeze... Humm , ill see how I feel on the day. maybe switch...maybe light..
Cheers
Cheers
Good man, you asked a sensible question and got some variable answers, you replied promply and nicely and thanked everyone, I wish all posters were like you, good on you.
Cheers
But no mention of the fan in the first “sensible” question.
Reply to Opinions on Wiring the lighting circuit at the 'switch' or ' at the 'light' in the UK Electrical Forum area at ElectriciansForums.net
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
